Back Fire
Old Jul 9, 2011 | 11:04 AM
Cobfree's Avatar
Cobfree
Default Back Fire
I had my original 327 rebuilt this past winter includeing the carb. Recently I am getting alot of back fire when the engine in hot and rev. from 600rpms. Also a little hard to start and at 4,500+ RPMs start to fall a little. She runs great until it gets hot (190).
Thoughts!
The carb is a rebuilt Carter.
Old Jul 9, 2011 | 05:40 PM
baxsom's Avatar
baxsom
timing?
Old Jul 10, 2011 | 09:49 PM
Phlash's Avatar
Phlash
Agree! First check timing. It sounds like it is too far advanced. Could also be dwell is not set right.
Old Jul 10, 2011 | 10:59 PM
hwcoop's Avatar
hwcoop
Or Lean condition caused by bad accelerator pump rubber
Old Jul 11, 2011 | 03:56 PM
Cobfree's Avatar
Cobfree
I will have to check the timing tonight
Old Jul 11, 2011 | 11:18 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
95% of the time, backfire through the exhaust is lean-out as stated above. Backfire through the carb is usually a timing issue.
Look for a vacuum leak first. There are many places to look since seemingly the entire car runs on vucuum.
Old Jul 12, 2011 | 08:47 AM
Cobfree's Avatar
Cobfree
It does backfire through the carb. Vacuums are fun to find.
Old Jul 12, 2011 | 09:15 PM
glackore's Avatar
glackore
Vacuum leaks can be found using some carb cleaner around the intake, carb, base plate, etc. The idle will go down when the juice finds the leak.
Old Jul 13, 2011 | 08:14 AM
Cobfree's Avatar
Cobfree
Great idea... Thanks
Old Jul 27, 2011 | 05:28 PM
Cobfree's Avatar
Cobfree
Your were correct, the timing was off! Thanks
Old Jul 27, 2011 | 11:23 PM
scottyp99's Avatar
scottyp99
C'mon, don't leave us hangin', how far off was it?
Scott
Old Jul 28, 2011 | 08:24 AM
Cobfree's Avatar
Cobfree
Don't know as I gave up and took it to the shop. Then leaving the shop the brakes went out. Joy of a 43 year old car. I will post the answer tonight when I pick it up.
Old Jul 28, 2011 | 01:01 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 73, Dark Blue 454
...Backfire through the carb is usually a timing issue...
And extremely impressive if you happen to be standing there and see the flash.
Old Jul 28, 2011 | 01:46 PM
Cobfree's Avatar
Cobfree
More like scared the %^&* out me as I had the air cleaner off.
Old Jul 28, 2011 | 02:11 PM
Easy Mike's Avatar
Easy Mike
Exactly. Been there, done that.
To Back Fire
