Electrical help PLEASE!
Old Jul 13, 2011 | 03:44 PM
1alemaker's Avatar
1alemaker
4th Gear
Default Electrical help PLEASE!
I'm a newer member and have read many posts. Thanks to all that I have gleaned info from. I have a '71 that has been a project for a few years. My sons and I got it running (non-original 454) and now I'm working on the electrical - I'm a pipefitter, not an electrician! When I connect the battery, the horn beeps (I replaced the relay - no help), and none of the interior lights work (instrument cluster, courtesy lights). The headlights and taillights work, though. There are a few wires at the firewall that have been snipped - I think one or some from the TCS?? Any help would be greatly appreciated. Thanks!
Old Jul 13, 2011 | 04:22 PM
dntoearthman's Avatar
dntoearthman
Does the horn beep or does it blow constantly?
Old Jul 13, 2011 | 04:29 PM
1alemaker's Avatar
1alemaker
4th Gear
Default electrical help
The horn blows constantly.
Old Jul 13, 2011 | 04:40 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you must break down to indiviual problems, one at a time to get good answers.
Horn blows, probable a shorted steering wheel switch.
Remove the green wire from the Horn Relay, located on drivers side above the a arm assy.
then go back later and trace out the short in the steering wheel.
provide detailed desriptions, wires cut? what color, where at?
if you really want help upload pictures so we can see you problem area.
Old Jul 13, 2011 | 04:45 PM
...Roger...'s Avatar
...Roger...
I would also unplug the black so the relay will disengage.
Old Jul 13, 2011 | 04:48 PM
Peterbuilt's Avatar
Peterbuilt
Welcome to Corvette Forum and congrats on getting your Vette running.
Did you pull the horn button off and see if the 3 plastic rivets are good?
No dash lights could be a bad ground. It's under the dash and near the hood release handle.
I'm a hobbyist and not a mechanic so disregard my help!
To Electrical help PLEASE!
