How to check for cradle sag?
Old Jul 14, 2011 | 12:21 PM
C6DuffMan's Avatar
C6DuffMan
Default How to check for cradle sag?
For a 71 454. Is there a measurement I can make to verify? I.E. between the upper A arm mounts? My alignment guy is having problems getting enough caster with a reasonable amount of camber. The front end was rebuilt by the PO, so I need to determine if there's an issue with the rebuild or if it's just cradle sag.
Old Jul 14, 2011 | 12:27 PM
rbrock's Avatar
rbrock
Looks like it is suppose to be 26-3/8" according to this thread:
http://forums.corvetteforum.com/c3-t...-question.html
Ray
Old Jul 14, 2011 | 11:12 PM
Drawmain's Avatar
Drawmain
I went thru this not long ago. Here is my thread that details it all and what I had done to fix it.
http://forums.corvetteforum.com/c3-t...radle-sag.html
Old Jul 15, 2011 | 10:39 AM
C6DuffMan's Avatar
C6DuffMan
OK, 26-3/8". And I think I know where to measure. Between the inside edge of the towers, where the A-Arms bolt on.
Old Jul 15, 2011 | 03:51 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Might you define "enough caster" and "reasonable amount of camber"?
To How to check for cradle sag?
