76 rebuild
Old Jul 17, 2011 | 02:50 PM
Black76's Avatar
Black76
Default 76 rebuild
Need help i just rebuilt the big block 454 install it was all set to spin tyhe engine to fine tdc to install distributor but get nothing. now the dash is apart i get lights and radio but no starter. im thinking naybe its the paint on engine from the ground wire from frame.but is there a interlock or clutch pedal in or something that im missing
Old Jul 17, 2011 | 05:22 PM
Big Block 69's Avatar
Big Block 69
I can't speak for other years, but on my 69 and 74 the clutch pedal needs to be pressed in to turn the starter with the key.
Rick
Old Jul 17, 2011 | 06:02 PM
Black76's Avatar
Black76
I just tried strting it with clutch pedal in bad no difference nothing
Old Jul 17, 2011 | 10:15 PM
scottyp99's Avatar
scottyp99
Methinks that your problem is that something that is supposed to be connected, isn't. I can't see it from here, so you are gonna have to get your test light out and get cracking. Sorry I couldn't be of any real help, but there it is.
Scott
Old Jul 18, 2011 | 09:25 AM
Black76's Avatar
Black76
looking at the wiring diagram it shows a cluch switch on manual trans can anyone tell me if that switch is on the pedal or mounted on the trans
Old Jul 18, 2011 | 09:33 AM
Peterbuilt's Avatar
Peterbuilt
Look near the pedal.
Old Jul 18, 2011 | 06:29 PM
roger3's Avatar
roger3
Black 76,
Assuming it started just fine before the engine swap, I would think its a simple wiring issue. Hook a test like to the starter wire on the solenoid and check for power. If you're getting power but the starter's not engaging, or even trying, then you don't have a good ground or dead battery. If there's no power, then start working backward from the starter until you get power.
I'm in the process finishing my 454 install into my 76 (automatic tranny). Love to see some pictures of yours. I'll have to post some of mine also. Is your's gonna be for street or strip, or both? Mine is for both, hoping to run just under 12.0's. My engine dynoed about 480hp, 560ftlbs torque. I was a little disappointed with those numbers (long story).
Good luck,
Roger
Old Jul 19, 2011 | 02:01 PM
Black76's Avatar
Black76
Roger
Thanks for the reply I got the starter issue figured out i feel so silly now i installed the smaller starter wire on the wrong post ops after taking the header off and switching the wire motor spins. My set up is a 454 with a 4 speed im look to just tear up the street with it . I have lots of pics i took when installing the motor just dont know how to post them yet
To 76 rebuild
