74 hood clearance 454 BB
Old Jul 19, 2011 | 11:37 PM
babalu95's Avatar
babalu95
Default 74 hood clearance 454 BB
Okay, so I just finished swapping in a 454 in my '74. Formerly, a 350. I got the engine out of an old dump truck. I knew I'd have hood clearance issues but in no way should stop anyone from going big block. So, I'm at this point and now need a proven combination that will ensure hood clearance. Currently, it has the cast iron intake manifold, a carb riser/spacer, and a Holly 750 vac sec carb. Any suggestions? In '74, these came 454 stock, with the flat hood (such as mine). So, I know there has to be a combo out there. Please advise.
Old Jul 20, 2011 | 07:41 AM
bashcraft's Avatar
bashcraft
There was a small block hood, and there was a big block hood. Which do you have?
Old Jul 20, 2011 | 04:57 PM
Ganey's Avatar
Ganey
You have the med. rise 73-79 hood. The stock BB intake works or Torker II.
68-72 SB have the flat hood.
Old Jul 20, 2011 | 07:18 PM
babalu95's Avatar
babalu95
Default Hmmm
I have the standard (small block) hood. As far as I know, in '74 there was only 1 hood, though. I found several photos of '74 BB with the same hood so I'm certain know there must be a way.
Old Jul 20, 2011 | 07:21 PM
Ganey's Avatar
Ganey
Yes, same (med. rise) hood SB or BB for your year. The stock BB intake works or Torker II.
Old Jul 21, 2011 | 01:28 AM
shrekviper's Avatar
shrekviper
If you're going to swap hoods, might as well go for an L88 hood. I have a Torker II under my stock BB hood and it's a tight fit. It would suck to swap hoods to find it doesn't fit. Also, getting the L88 hood will allow you to run a carb/spacer/intake combo that really works together.
To 74 hood clearance 454 BB
