4 speed shifter
Old Jul 20, 2011 | 09:13 PM
Black76's Avatar
Black76
Default 4 speed shifter
how many bolts are there that bolt the shifter to the transmission. I installed the shifter with 2 bolts and after hooking the linkage up when shigting gears the whole shifter seems to be moving which doesnt seem normal.This is on a 76 4 speed manual.Are there more then 2 mounting bolts.
Old Jul 20, 2011 | 11:51 PM
birdsmith's Avatar
birdsmith
There should be two bolts that hold the shifter assembly onto its attach bracket, which is held onto the side of the transmission by three bolts. This for a Hurst shifter...The factory unit is bolted onto a large bracket which is connected to the frame. If this is what you have you'll have to get underneath and make sure everything's tight.
Old Jul 21, 2011 | 02:14 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
This one's out of my '72. I'm guessing same as yours. Look it over; there are several pair of bolts holding this together.
Old Jul 21, 2011 | 02:22 PM
Dustup7T2's Avatar
Dustup7T2
Found one more:
To 4 speed shifter
