1968 driver rear view mirror correct
Old Jul 21, 2011 | 01:24 PM
rphrwr's Avatar
rphrwr
Cruising
Default 1968 driver rear view mirror correct
Does anybody know the correct location for a 68 drivers door. location?
Door has been worked of and many holes put in over the year, the metal backing as been removed and what to install in the correct location any help apprec. Thanksc
Old Jul 21, 2011 | 02:00 PM
qtlow's Avatar
qtlow
Default Location
Depends on your build date for the absolute location. I believe Chevrolet moved it a little bit during the 68 production year.
Old Jul 21, 2011 | 04:09 PM
rphrwr's Avatar
rphrwr
Cruising
Default 1968 corvette mirrorlocation
this 68 car was built in mid may. Location is unknown due to several holes drill.
Old Jul 21, 2011 | 04:20 PM
thatcorvetteguy's Avatar
thatcorvetteguy
May should be the late location point. It's the same and 69-76?
Old Jul 21, 2011 | 04:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Early position was within an inch or two of the leading edge of the door. Later position moved rearward same spot as 69-77. Not the best example to be sure, but the position is correct:
Is there a mirror on the car now? If the position is good, you could use the existing holes.
Old Jul 21, 2011 | 04:26 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Yours would have the later location. After early March the mirror was moved back about 6 1/2 inches from the earlier location. I have an early car so I can't give you an exact location for yours.
Old Jul 21, 2011 | 06:41 PM
rphrwr's Avatar
rphrwr
Cruising
Default 68 mirror location
I own a 71 corvete sounds like i can use that location huh
Old Jul 21, 2011 | 10:07 PM
qtlow's Avatar
qtlow
Yes, a mid to late production 68 will use the same location as your 71.
To 1968 driver rear view mirror correct
