Finally got aroud to dropping the BB 427 in the hole.
I have 3931063 casting oval port heads.
The issue is the 2 1/8 in primary headers are too big for the head port mounting surfaces, there is a 1mm of header flange coverage on the machined head surface....... ( gasket will last all of 5 mins)
Has any one had this issue? looks like new heads are the answer
I don't think I ever hit that before...and as much as new heads are great....a better choice might be a set of 1-7/8" headers. 2-1/8" are way too big for a 427 oval port motor.
I got a 1-7/8" Hooker super comp. and I already have a serious ground clearance issue!, I spend at least 40-50 hours working on them to fit my car, and now I have to remove them because of the ground clearance issue. I will NEVER buy Hookers again, I had to dimple a couple of places, and had to use the angle grinder to clear the flange from hitting the lower head bolts, and the passenger side collector is already hitting the floor. It just like they started fabricating headers for C3s yesterday! , I will buy from Hedman this time. Sorry for the negative post, but I have to steam out a bit!
Doing the opposite thing shortly - currently have Hedman 1 7/8" headers - they fit great on 427/390 - passenger side literally falls in to place - drivers side requires removal of alternator and clutch 'Z' bar - collectors ARE close to floorpan. Will be fitting 2 1/8" Super Comps to my Brodix headed stroker - whether the additional flow will add any HP/TQ remains to be seen! - hope ground clearance won't be an issue!
ground clearance is a problem as they will drag trying to go over even the smallest obstacles....your collector flanges are the lowest......and Hookers fit is good but they rust
JIM
Hi Jim,
Yeah I know primary tubes are too big, they are side pipes so did not have much choice, might force me to change the heads now, like to get the compression down to pump gas level, these heads are 100.9 chambers.
Hope to go with some small rectangle ports.
I have shipped these pipes from your side of the world, so they literally owe me thousands, so on the hunt for some local used heads.
Will post some pics
Richie
Richie
These are side pipe headers, apart from the port issue and interference on the head studs look like they will fit well.....fingers crossed
