'75 L48 Timing Questions
First of all, when running the eng rpm up to the 2500-3000 range the timing mark seemed to jump around a bit, spanning about a 6 deg spread - what would cause that?
Secondly, after setting as best I could the recommended 36* and reconnecting the vacuum advance the enging would "pop" and maybe "bang" (like backfire) when the gas was released with the rpm up in the 3000 range. I retarded to 34* and I couldn't hear any popping or banging when i released the gas while driving, but I still get it sitting in the driveway if I quickly punch the gas up. Any ideas there?
I've had this car a month from my dad and I'm learning on the job here so any advice or suggestions are appreciated.
BTW - I live in Calgary, Alberta which has an altitude of about 3600' and the car came from Victoria, British Columbia sea level
