q-jet weiand intakes
Old Apr 26, 2002 | 09:05 PM
derv3tt3's Avatar
derv3tt3
Default q-jet weiand intakes
How do you pick between Weiand actionplus or stealth?Does it go by rpm"s? :seeya :chevy
Old Apr 26, 2002 | 09:27 PM
tnt76vette's Avatar
tnt76vette
Default Re: q-jet weiand intakes (derv3tt3)
I have the "Action Plus". It will accept either spreadbore or square bore carbs, it a dual plane for good low end torque and it fits under my '76 Hood, altho I did have to shorten the Air Cleaner Stud.....it was poking a hole in my insulation...... :D :D :D
Old Apr 27, 2002 | 08:53 AM
Ganey's Avatar
Ganey
Weiand Action Plus works very well for many w/ milder setups. For higher hp setups, the Stealth. You should give your setup incl. yr. & trans.
Old Apr 27, 2002 | 10:35 PM
derv3tt3's Avatar
derv3tt3
Default Re: q-jet weiand intakes (Ganey)
Ganey,
My engine is a 383, 268xe cam,performer rpm heads ,
auto with 336 gears.
Steve :chevy
Old Apr 28, 2002 | 12:53 PM
Ganey's Avatar
Ganey
W/ the Q-J, the Performer 2101 or Action + w/ a spacer will work.
Old Apr 28, 2002 | 03:36 PM
derv3tt3's Avatar
derv3tt3
Weiand makes a Stealth for the Corvette and q-jet you would still go with the actionplus?My original post was (383 VS 383). :seeya
To q-jet weiand intakes
