Hood sits lower than body
Old Jul 26, 2011 | 10:56 AM
behardt91's Avatar
behardt91
Default Hood sits lower than body
I have a 79 hood on a 77 front end and it's not sitting properly. First off, the front of the hood (up by the headlights) sits higher than the body. And secondly, as you look back there are parts of the hood which sit lower than the body. I'm not sure what to do about it. Anyone else had this problem?
Old Jul 26, 2011 | 12:01 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Ehardt1979
I have a 79 hood on a 77 front end and it's not sitting properly. First off, the front of the hood (up by the headlights) sits higher than the body...
Remove shims if there are any under the hood hinges.
Raise the nose.
... And secondly, as you look back there are parts of the hood which sit lower than the body....
You can purchase rain gutter blocks which will bring the hood edges up even with the fender tops.
AIM shows them. Placement is by trial and error and you may have to shave them to get a perfect fit.
Old Jul 26, 2011 | 05:35 PM
behardt91's Avatar
behardt91
How do you raise the nose?
Old Jul 27, 2011 | 10:23 AM
Easy Mike's Avatar
Easy Mike
Bar under the nose; two reinforcements on each end of the headlight header bar attaching to the fender skirts. Purchase the AIM and take a look.
To Hood sits lower than body
