Won't stop running
Old Jul 27, 2011 | 10:43 AM
wagsrb's Avatar
wagsrb
Default Won't stop running
I have a 1978 pace car and the window washer motor won't stop running it run all the time any ideas.
Old Jul 27, 2011 | 08:50 PM
'75's Avatar
'75
I would check the switch to start with.
Old Jul 27, 2011 | 09:10 PM
Timsride's Avatar
Timsride
There is a plastic round wheel under the cover on motor. It has a steel plate above that activates the washer pump. It has a small tab that gets pushed to the side and kinda twists the plate sideways so it no longer runs the pump. The next time you push the button a magnetic pickup lifts that plate back into place. Thats how the earlier Chevs were made not sure if it changed after 76? Its a stupid design and I cant believe someone actually engineered this. if its the same design you will probably have to play with that metal plate to get it working (Properly?) Thats the best description I can give without a diagram.
Old Jul 27, 2011 | 09:13 PM
'75's Avatar
'75
My 75 and also later ones have an electric pump on the reservior seperate from the wiper motor. You are correct on the problem for the erlier ones though.
To Won't stop running
