Quick master cylinder question
Bad boosters- In my experience a bad booster usually just gives a hard pedal with no assistance,like running one out of vacuum will do. I've had boosters hiss excessively while applying the brake but would still give assist. When the rod is too short , if I remember right,the pedal goes down quickly before contacting the piston in the master.
Most cars I work on the brakes is after I've done a brake job but I have done bleed jobs only and have run into some pretty weird stuff happening.
Sounds like you are having some success at last, or progress at least. Is it possible that the vacuum in the booster is building up over time as you drive and apply throttle? That may not happen at idle in the garage, but could happen at higher revs as you drive. What is your vacuum pressure at idle and higher revs? I'm just guessing here, as usual. Maybe your shop guy has a vacuum gauge he could bring along if he is coming by this PM.
Ed
BTW, bedding the pads always helps, but not so much with pedal height. It just grabs better sooner, so you don't have to press so hard. Is that what you're feeling?
I thought you looked at your car and the pic I posted and also took the pin out and determined that the pedal couldn't go up higher.
The people that had booster rod to pedal problems, unless I misunderstood, had the wrong booster/rod and could make up around an inch at the rod and pedal.
I really doubt you have had 4 masters bad, but you never know.
Yes, usually from a crack in the diaphragm.
I'm afraid I'm still with the booster malfunctioning internally, especially after all these masters.
I suppose you could try a known good master from another car and see if it acts the same way.
If you can find a route safe enough, perhaps try driving without vacuum to the booster to eliminate it. The pedal will be very hard, but if it stays near the top, then it would eliminate the booster.
As far as your vacuum level, the lower the vacuum, the harder and higher the pedal.
Sure wish I didn't have so much to do to get ready to go south,Id take a road trip and find out WTF is going on.
I don't know if the vacuum pressure buildup has anything to do with the improved brake performance. I'm just spit-balling the results you are having when you drive for a bit. What changes to make the brakes wake up?
My understanding of the vacuum system is this:
1. Car off, with the vacuum bled off by depressing the pedal a couple times, atmospheric pressure on both sides if the booster diaphragm(s).
2. Car on, vacuum on both sides of the diaphragm until the pedal is depressed. At that time atmospheric pressure enters the pedal side while there is still vacuum on the master side of the diaphragm giving the assist. (Could be wrong so correct me if I am, anyone, please)
Maybe the vacuum on the pedal side is not released until you hit the brakes a couple times as you would when driving? (Don't think so, but you could try that before setting off.) What else changes???? Friction, vibration, fluid compression, what?
Ed
Better yet what changes to get the results you are seeing?
I wonder if o ring pistons with no springs could cause this in some cases ?
edit- How about a pad that the metal backing plate is too long and the fiber part of the pad never makes it fully to the rotor surface ? It flexes and springs back.
Here is some info on bedding the pads, it always helps a bit. I compare it to having grease and oil on the pads and rotors, you would be pushing harder and have a little lower pedal to get enough clamping force to stop.
The last car I did, I had some extra time and wanted to experiment a bit.
I've got a hydraboost setup, but didn't want to use it, it shouldn't be necessary for this weight of car, so I tried this.
The car had no brake problems, new ss calipers, new rubber hoses, old pads, new master. For reference, the braking started less than 1/2" from the top and full hard pedal lockup was a little over 1/2 way to the floor, same as oem new.
I switched to a truck master that had 1-1/4" bore ($50.00), rebled, and that brought the full hard lockup to a little less than 1/2 pedal, but also made for a little harder pedal feel and gave a lot better feedback. One could do all the math for the extra master volume and calculate the difference in stroke and pedal force.
The reason why I tested it was because I wanted a less mushy pedal than they originally came with.
Most people couldn't tell the difference looking at the masters.
There are also larger alum masters that fit for around 100 bucks new.
I would do that mod to any I will ever own.
Only difference externally is that that the larger reservoir is in the rear instead of front.
How hard would it be to bore a vette cylinder to 1 1/4 ?
Hmmmm
Master is for 4 wheel disks, so there should be no problems with springs.
Not enough meat to bore the 1-1/8" vette master anyway.
The brakes should work 100% from the moment you start the car. Keep digging until you find your "magic bullet".
But I have to say I feel for Billy, that sucks......damn...
Sounds like it still may point to a booster issue.
My new build does not give me much vacuum at idle, like around 11'' even lower once its in gear. I do not think that is adequate to operate the booster effectively. I am unable to lock up the tires now, was able to with old tired engine with higher vacuum.
I have heard from another source and also read in another post that if you add a NON power manuel master to a booster, this increases pressure maybe. As mentioned above they said it will stand the car on its front bumper since the bore diameter/piston is smaller. Something I am thinking about trying before I go to a electric vacuum pump or Hydraboost.
Maybe Noonie or Roger can chime in on the Manuel (non power MC) with a booster. Worth a try at this point as well as a new booster to try.
Good luck,
I haven't driven a power brake car with the smaller diameter master cylinder,that I know of.
