Battery properly installed
Old Jul 28, 2011 | 07:36 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Battery properly installed
Does anyone have a pic of the battery installed in an '80, maybe the empty box showing the hold down clamp or whatever, and then a pic with the battery installed.
A small 2x4 has worked fine for 15 years but I want to install it correctly now
Old Jul 28, 2011 | 07:49 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Wayne I've been using this with no issues for many years. You might be able to find it locally at an auto parts store:
http://www.summitracing.com/parts/BRL-1821/
Old Jul 28, 2011 | 08:15 PM
stpman's Avatar
stpman
Hey Wayne
Check out the pictures on this page lower right
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={04f07523-002c-458c-85b2-55f9163f35b9}&gid={83ccd8a0-c5ac-4403-93c0-2eb0185e4d35}&GroupName=Battery+Mounting &pname=67-82+Battery+Hold+Down+Clamp&Referer=&Alia s=&ptct=SGR-SR&CTitle=&#
Old Jul 28, 2011 | 10:38 PM
MotorHead's Avatar
MotorHead
Thanks Steve, there are pics there that show what's needed. I have the front retaining piece and I have that hold down clamp in the back but there is nothing there at the back to bolt the clamp to and I don't suppose that's gonna be easy to find.
Mike I might have to use a solution like yours, looks like you just drill two holes in the bottom of the box for those brackets ?
Old Jul 28, 2011 | 10:48 PM
...Roger...'s Avatar
...Roger...
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Old Jul 28, 2011 | 10:53 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Beat me to it!
Old Jul 30, 2011 | 11:13 AM
MotorHead's Avatar
MotorHead
I have that, what I don't have is any thing to bolt the hold down clamp to in the back of the box facing toward the rear, I have a big hole there, looks factory, never seen bubba making anything so round
I bought the Canadian tire hold down kit, will I lose any points if I drill two holes in the battery box
Old Jul 30, 2011 | 12:02 PM
...Roger...
I think you have this and you need whats in the first link to go UNDER your big hole.
Old Jul 30, 2011 | 12:47 PM
MotorHead's Avatar
MotorHead
I guess that's why I wanted a pic. The hole is 2 inches in diameter. There is nothing at the back of the battery for that hold down clamp to bolt to. I have that hold down clamp. The picture looks like there are 2 blocks ?
and a reinforcement for under the box part number 173014, maybe I still have that under there.
I know someone had a pic of the empty box and then with the battery properly fitted. I would rather do it the correct way, looks like I have most of the parts, just don't know how they fit together
Old Jul 30, 2011 | 01:24 PM
...Roger...
You might have to wait for an acual pic,I don't recall the block being.If I had a car here I'd go look.Here is a better drawing from a 73 AIM.
Old Jul 30, 2011 | 01:48 PM
MotorHead's Avatar
MotorHead
WOW ! Thanks Roger maybe an '80 is different I have most of those parts except for the blocks
Wayne
Old Jul 30, 2011 | 02:02 PM
...Roger...
No problem Now I'm really curious,I might have to run down a car to look at today.
Old Jul 30, 2011 | 05:10 PM
MotorHead's Avatar
MotorHead
Well one thing I know with those types of battery hold downs you have to have a battery with exact factory specs on outside, an Optima Red Top ain't gonna work
To Battery properly installed
