steering wheel locking plate re-install?
Old Jul 29, 2011 | 04:32 PM
retaf's Avatar
retaf
Default steering wheel locking plate re-install?
Sorry I have to ask but I can't recall which way the locking plate came out of the steering column after I removed the retainer. Does the center raised ridge of locking plate face down or up?
Old Jul 29, 2011 | 04:37 PM
76stingracer's Avatar
76stingracer
The lock plate only goes in one direction because you have to be able to put the clip through it to hold it in place.
Old Jul 29, 2011 | 05:25 PM
retaf's Avatar
retaf
the reason I ask is because when it's installed with the retainer clip and I flip the turn signal left or right then the horn blows. So I continue the search......
Old Jul 29, 2011 | 05:41 PM
...Roger...'s Avatar
...Roger...
raised edge up
Old Jul 29, 2011 | 06:03 PM
noonie's Avatar
noonie
Did you install the plastic insulator #7808385 properly?
Old Jul 29, 2011 | 06:33 PM
retaf's Avatar
retaf
Previously anytime I installed the lock plate and I initiated the turn signal the horn would honk. I looked at it closely and wondered what I did differently. I noticed a screw I had replaced holding the crossover arm in place. The screw had a thicker head on it than the original and once I found a better substitute it now appears to have stopped. I'll keep checking as I finish the installation of the steering wheel components but I think that was the problem.
To steering wheel locking plate re-install?
