Door latch problem...
Old Apr 27, 2002 | 03:58 PM
Vetteboy 72's Avatar
Vetteboy 72
1st Gear
Default Door latch problem...
I replaced my outside door handle. When reinstalling the door panel I must have pinched the lock mechanism or something. The lock is out of adjustment and will not unlock. OK, except I closed the door! Does anyone know how to open the door when the lock is stuck on? I'm pretty sure I need to open the door, before I can take off the door panel and fix whatever I did. I noticed there is a notch in the inside door panel. It looks like you could get at the latch with a screwdriver or something from inside the car. Any suggestions would be greatly appreciated! :seeya
[Modified by Vetteboy 72, 8:01 PM 4/27/2002]
