75 running issue
Old Aug 3, 2011 | 12:17 PM
dudleyff1018's Avatar
dudleyff1018
1st Gear
Default 75 running issue
i have a 1975 L-82 im having a problem keeping it running. i replaced the fuel filter. the fuel pump is working fine. it will only run when i pour gas into the carb. any suggestions
Old Aug 3, 2011 | 03:14 PM
Peterbuilt's Avatar
Peterbuilt
Default With a fire extinguisher handy...
Disconnect the fuel line at the carb and see if the pump is pumping fuel, if so then see if the needle and seat in the carb is stuck.
If no fuel is pumping see if the rubber lines before the pump are good.
If good there then check the sock in the tank.
