Help.....transmission!
Old Aug 3, 2011 | 04:22 PM
DustersVette's Avatar
DustersVette
Default Help.....transmission!
Ok, I took my 71 4 speed out to drive on Saturday. Ran beautifully, went to pull into a stop. Downshifted, then it would not go into any gear. Pushed her into a parking spot, went inside for a bit then came back out....still will not go into any of the 4 forward gears, but will go into reverse. Is this a transmission problem, vacume problem or what.....HELP!
Old Aug 3, 2011 | 04:52 PM
MelWff's Avatar
MelWff
the shifter lever bolts on the side of the case have loosened. jack the drivers side up, push all levers into neutral and retighten the bolts.
Old Aug 3, 2011 | 08:05 PM
DustersVette
Would you have a diagram of this or picture of these....any help would be great and let me know the easiest way to access this area to tighten the bolts. Thanks!
Dusty
Old Aug 3, 2011 | 08:34 PM
Chuck72's Avatar
Chuck72
Can you shift it into the forward gears with the engine off and clutch pushed in?
Old Aug 3, 2011 | 09:29 PM
DustersVette
No, cannot shift into any forward gear.
Old Aug 3, 2011 | 09:57 PM
thatcorvetteguy's Avatar
thatcorvetteguy
Sounds like you have a shifter problem. Is the neutral gate the same or is it narrower?
Old Aug 4, 2011 | 11:08 AM
MelWff's Avatar
MelWff
heres a PDF showing the linkage and adjustment
http://willcoxcorvette.com/instructi...ons_locked.pdf
Old Aug 4, 2011 | 11:40 AM
DustersVette
Awesome, thanks!
To Help.....transmission!
