Radio on 78
Old Apr 28, 2002 | 01:18 AM
medic007's Avatar
medic007
Cruise-In IV Veteran
Default Radio on 78
I just got an original am/fm 8trac and CB radio. I will mount it in the original slot. Can I mount my Cd player behind the seat or get a changer? I enjoy my cd's and want to be able to listen but need some suggestions as to how to do it.
Old Apr 28, 2002 | 01:59 AM
SizzleChest's Avatar
SizzleChest
Default Re: Radio on 78 (medic007)
im in the same boat. i need a stock radio (or even better, a radio delete plate), but i would like to be able to listen to cds. i was thinking of removing the glove box liner and making some sort of bracket for a cdplayer. it needs to be somewhere where you can control the volume and tracks and whatnot so to me, behind the seats isn't an option. what do you think about that?
Old Apr 28, 2002 | 02:13 AM
kermit1654's Avatar
kermit1654
You need an FM modulator. This will allow you to feed the signal from a cd changer or a MP3 player to the factory stereo. This is the best you can do with and still use the factory unit. Here is a url that discribes it. Cost is around $30. http://www.hobbytron.net/product581.html
Old Apr 28, 2002 | 09:45 AM
Pete79L82's Avatar
Pete79L82
I put in a CD changer that was FM modulated. It is a 6 disk Pioneer unit. Mounted it in the compartment behind the passenger seat. You set the factory radio to a certian FM station and the CD changer plays through the radio. You control the volume with the radio. A small remote control comes with the changer to select the tracks and disk. I wired mine so it lays near the passenger seat. Then when I am not using it I tuck it in between the seat and the console and you can not see it.
Old Apr 28, 2002 | 10:21 AM
78Vette-SA's Avatar
78Vette-SA
I went the reverse route. I took out the original 8-TRack and boxed it up carefully and have it stored away along with the original speakers, all working.
I installed a Kenwood Corvette right in the same slot and stuck a 10-disc changer and Bazooka sub in the rear. If I ever were to have the car judged (doubtful), I could put it all back easily.
Old Apr 28, 2002 | 08:04 PM
medic007's Avatar
medic007
Default Re: Radio on 78 (78Vette-SA)
I like the changer idea. THe only concern is that the original has *****, I am not sure you could get it on the exact station number.
Old Apr 28, 2002 | 08:19 PM
Pete79L82's Avatar
Pete79L82
Mine is The factory AM-FM-CB with ***** and getting it onto the correct station is not hard. The signal from the changer is very strong so it tunes in very easy. Then I set one of the pushbuttons to that station.
Old Apr 29, 2002 | 12:54 AM
medic007's Avatar
medic007
Default Re: Radio on 78 (Pete79L82)
Pete,
If you don't mind I think I will copy your set up. That is the best idea that I have heard so far. :cheers:
Old Apr 29, 2002 | 11:56 PM
7SILVER8's Avatar
7SILVER8
Do your tops still fit back there??
Old Apr 30, 2002 | 12:06 AM
78Vette-SA's Avatar
78Vette-SA
Default Re: Radio on 78 (7SILVER8)
If you mean mine, yes, no problem. I put them in separate padded bags and throw them back there.
Old Apr 30, 2002 | 01:43 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
What you could do is get a FM modulated changer and mount it in the back. I have a dedicated 12 disc mounted on a plank of plywood. I cut the plywood to fit back there, mount the changer vertically, and I still have room for the tops. I'm also about to mount my fire extinguisher and speakers to the plywood, so just something to think about if you want to add more stuff, and also not permanent. Just disconnect the changer and pull out the plywood with changer and all and it's back to original.
To Radio on 78
