window adjustments/etc
Old Aug 7, 2011 | 06:48 PM
onaqwst's Avatar
onaqwst
Default window adjustments/etc
curious if there is a set of instruction somewhere that gives a good breakdown and redoing the windows/adjusting. I need to clean my tracks/etc and get the alignment with the weatherstripping correct
Old Aug 7, 2011 | 07:01 PM
Duke94's Avatar
Duke94
The AIM has a very good procedure for window adjustment. Get the T-top correct front and rear B4 you even start on the window.
Gary
Old Aug 7, 2011 | 07:38 PM
Peterbuilt's Avatar
Peterbuilt
The AIM is very good and here's a How-To with lots of pictures...
http://tech.corvettecentral.com/2011...glass-service/
Old Aug 8, 2011 | 09:28 PM
Korevette's Avatar
Korevette
Study the printed material and the operation of the unit. There are 5 dimension to a side glass: Up and Down, Front to Back, Left to Right, In or Out and Time.
Once you understand the dynamics it becomes fun in getting the best results. Just as a note, to always bring you back to what you have before you start is you can 'mark' the positions of the existing hardware prior to adjustment.
Good luck to you.
To window adjustments/etc
