EGR/EFE SWITCHES
Old Apr 28, 2002 | 02:22 PM
JK80's Avatar
JK80
Default EGR/EFE SWITCHES
Can someone tell me what are the plastic pieces at the ends of the emission hoses that connect to the EGR/EFE switches? What is their function and where do you buy them? On my "80" the hoses connect directly to the switches,is this ok?
-jk80-
Old Apr 28, 2002 | 04:27 PM
Paul L's Avatar
Paul L
Default Re: EGR/EFE SWITCHES (JK80)
I am not familiar with plastic pieces at the ends of the hoses. Here is a spare EFE valve I have. As with my car, the rubber hose just pushes on. And never moves.
Old Apr 28, 2002 | 05:12 PM
JK80's Avatar
JK80
Default Re: EGR/EFE SWITCHES (paul79)
I'm talking about the other end of the hose where they connect in the intake manifold and thermostate. In between the temperature control switch and the end of the emission hose.
-jk80-
Old Apr 28, 2002 | 05:19 PM
Paul L's Avatar
Paul L
I can't get to my car today to have a look or take a pic so I will have to leave it to others to reply to your query.
Old Apr 29, 2002 | 10:54 AM
UKPaul's Avatar
UKPaul
If you're talking about the rubber moulded bit that joins the hoses to the TVS then I don't know!! I Just connected the hoses directly onto the switch with no problems.
:cheers:
Old Apr 29, 2002 | 03:24 PM
Kingt's Avatar
Kingt
Default Re: EGR/EFE SWITCHES (UKPaul)
Sounds like a check valve? Are they a different color on each side?
Old Apr 29, 2002 | 09:37 PM
bluevette's Avatar
bluevette
If I remember right, they are temperature activated switches (which is why they are located in the thermostat housing). As for where to get them, I found mine at a local AC Delco dealer when I lived in Colorado a couple of years ago. Call your local Chevy dealer, if they don't have it, they should know who does. That's how I found the AC Delco dealer. Hope this helped a little. Good luck.
John
To EGR/EFE SWITCHES
