Yep, it's me again...MajD. Anyway, my '79 has decided I need to investigate the cause for no turn signal or hazard lights. They were working fine, then suddenly nothing. I crawled under the dashboard an looked at the fuse box. There are a few questions.
First, I see two round objects that look like they could contain relays, one is blue plastic and the other is metal. Is one for the blinkers and the other the hazards? If not, what are they? The lights work when I turn the headlight switch on, so I know it's not the bulb or wiring.
Second, does anyone have a diagram of the fuse box. My fusebox is so old the the labels have worn off I cannot tell for sure what systems the individual fuses are powering. I checked them all by pulling them one at a time and putting them back, but a diagram sure would be helpful. Thanks.
