Motive brake bleeding question
Old Aug 9, 2011 | 10:31 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Default Motive brake bleeding question
I installed new lines during my body off on my 69.
Took the vette for a short ride yesterday and the brakes were still very soft.
I plan on bleeding again today and didn't know if while the Motive is attached I can see if the brakes are hard or are they artificially hard because of the pressure from the Motive?
What I'm getting at is i'll bleed till they're hard but don't want to have to take the Motive off every time I want to check to see if I got it correct or not.
Old Aug 9, 2011 | 10:49 AM
joefloyd's Avatar
joefloyd
You need to check the air pressure at the motive bleader, and there is no need to push on the brake pedal,just open one bleader at a time the air pressure in the motive will push the fluid and air out. Keep checking the pressure in the motive because it will drop and the fluid passes in to your brake lines.
Old Aug 9, 2011 | 11:41 AM
Jeff_Keryk's Avatar
Jeff_Keryk
Here's what I do (others will chime in): Remove wheels and get the back end up in the air. Use low pressure (10 psi). Start with RR caliper. Bleed until clean fluid flows. Tap caliper with hammer to help trapped air. Work around car. Go around twice. If you are replacing Master, be sure to bench bleed. Anyways, that's what works for me.
Old Aug 9, 2011 | 12:22 PM
TopGunn's Avatar
TopGunn
I have a Motive and agree with the above posts but I don't put fluid in the Motive, I just keep the master cyl full and apply air pressure to it using the Motive. Makes for a cleaner job without spilling fluid.
Old Aug 9, 2011 | 12:27 PM
noonie's Avatar
noonie
You can apply the pedal and test the brakes with the Motive attached.
Old Aug 9, 2011 | 01:39 PM
jnb5101's Avatar
jnb5101
tap the calipers with a rubber mallet as you bleed them, it will help dislodge air bubbles. by the way, you did bleed the inner and outer vents on the rear?
Old Aug 9, 2011 | 01:51 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
why would you?
Old Aug 9, 2011 | 06:19 PM
PUNISHER VETTE
Originally Posted by SanDiegoPaul
why would you?
that was my question. If I can apply and what I feel with the Motive on will be the same as if I took the motive off.
What I don't want to do is bleed, take the motive off, put the cap back on, and then get in the car and test the pedal just to find out it's still sloppy.
Old Aug 9, 2011 | 07:26 PM
noonie's Avatar
noonie
why would you?
The Motive only has from 0-50 psi compared to 0-~1800psi, so if nothing else it assures the pistons and linings were seated to the rotors. Brake pedal height also can test for air or leaks in the system, especially if there is no difference in color between old and new fluid.
I do it all the time without second thought.
Old Aug 9, 2011 | 09:38 PM
PUNISHER VETTE
Found the issue. Passenger front had a ton of air bubbles in it.
And like stated above before I packed everything back up and put the tires on I was able to test the pedal and it was nice and hard!
God Bless the Motive Power Bleeder
Old Aug 9, 2011 | 11:22 PM
Mooser's Avatar
Mooser
Just need to keep it topped up, seemed like a waste to put a bunch in the Motive
Mooser
Old Aug 10, 2011 | 06:42 AM
PUNISHER VETTE
Mooser
I've seen this so many times already but why wouldn't you fill the motive?
You can't see in the cylinder so how often are you releasing pressure, taking the top off, and checking, putting it back on, pumping it up again...
It just takes that one time bleeding it dry to cost you another hour of bleeding. And don't you have to bench bleed if you bleed the MC dry?
You can do what you want but I see no reason not to fill the motive. Mine last night didn't leak a drop when I took it off. when you release pressure the excess fluid gets sucked back into the unit and you're left with a nice full MC. That's what it was made for....
Old Aug 10, 2011 | 08:50 AM
...Roger...'s Avatar
...Roger...
Removing the Motive top from the master is leak-free IF you don't fill the master to the top before you put the top on. I leave the master fluid level down about 1/2" before installing the top. If you start down 1/2" you will finish 1/2" down.
I also only put around 6lbs pressure in the Motive , if I want pressure I step on the brake pedal , that gives REAL pressure.
In my case the Motive becomes a constant fluid supply but under low pressure,makes it really nice to have that constant slow flow while I tap all fittings, lines and calipers with my trusty 3/4" wrench.
Old Aug 10, 2011 | 01:30 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
after the first time i have always done my bleeding dry, but out of curiosity, do you clean it each time afterwards and how long do you leave the brake fluid in there? what are you using to clean it with rubbing alcohol, brake clean or something else?
Old Aug 10, 2011 | 04:22 PM
...Roger...
If there is a small amount left I dump it,if there's a pint I fill the pint bottle and any left over I keep for cleaning purposes. I leave the tank upside down to drain for a bit then clean the tank with a couple ounces of denatured alcohol , put the pump back in until the next time.
Old Aug 11, 2011 | 10:30 AM
bobs77vet's Avatar
bobs77vet
ok thks
To Motive brake bleeding question
