What is the best engine oil for an old stock 350
Received 3,043 Likes
St. Jude Donor '05
any
:inbeforethemustusesecretsauceoilguys:
Organic diesel truck/hvy equipment oil such as Rotella T, Delo, Delvac ... or ... or the most expensive boutique oil available
"Don't cultivate a luxury you cannot support as a habit" -- Orson Welles, 1952
For readers interested in more background on using diesel oil and why it's not on the flat-tappet oil sticky, these two reads are worthwhile:
http://forums.corvetteforum.com/1578321984-post33.html
http://forums.corvetteforum.com/1578329098-post40.html
Everyone of course needs to make up their own minds
Note regarding switching from mineral to synthetic
There's a lot of feedback that making this switch causes engines to develop leaks. This can be the case, but it's important to understand why. Synthetic oil is more solvent than mineral oil, meaning that it can clean and remove deposits left my mineral oils - and expose worn or damaged oil seals. If your engine currently uses more than about 1 quart every 1,000 miles, you may experience leaks by switching. Note that this solvency is a good thing; this is exactly what keeps an engine far cleaner when running synthetic.
It does happen with some high-milage engines From the oil sticky:
In the interest of telling the whole story and not just convenient extracts:
http://forums.corvetteforum.com/c3-t...-question.html
I'm super glad I stocked up on the predecessor to BradPenn; Wolfshead straight 30wt when Sears Roebuck had it on sale for 59 cents/quart in plastic bottles. Cause everybody knows the best lubricating oils come out of the ground in northwestern Pennsylvania. And have been since 1859.
Well, let's talk about that perspective for a moment
GEN I SBCs might have been designed a long time ago - but I think we'd all agree that these engines have benefitted a bunch from new technology. HEI, retrofit roller cams, Vortec and other incredible cylinder heads, retrofit fuel injection, hypereutectic pistons, etc. 500 FWHP used to be pretty darn hard technically to make happen - now it's just a matter of money
The benefits of synthetic oil are crystal clear, and it works just fine in GEN I's as long as they're sound. New technolgy = better in this case, IMHO
OK, I read the sticky, and cant find any of these oils stocked at local stores. Or if they have them they don't have the correct weight
Whats a recommended oil I can buy off the shelf that I dont need to order online?
I'm surprised that no local stores carry Valvoline, Moble 1 or Castrol in the weights listed...very common weights and brands and contrary to what others note, not exactly "boutique" ;-) I would expect that any parts store that carries those brands would be able to get you a few cases of whatever you choose.
IMHO, I'd bite the bullet and put in the order. I wouldn't take the shortcut route...but it's your 'Vette.
