Exploded view of '80 horn
http://jimshea.corvettefaq.com/?cat=5 Somewhere in there is exactly what you are looking for.
I hate to say it but the blown up diagram isn't enough for me it is hard to understand exactly how it goes together is there
any other diagrams out there ?
http://forums.corvetteforum.com/c3-t...n-contact.html
http://jimshea.corvettefaq.com/wp-co...ev13my2010.pdf
http://jimshea.corvettefaq.com/wp-co...ev09ja2010.pdf
http://jimshea.corvettefaq.com/wp-co...ev02oc2010.pdf
http://jimshea.corvettefaq.com/wp-co...ev21mr2009.pdf
Jim
That's pretty mature I'll have to make a note of your help. And you've been here 10 years and no one has helped you ? Maybe you could point us to a post where someone was as childish as in your post, the posts go back almost 10 years, maybe there is one but do you think it is smart to post something that ridiculous in my thread ?
Wilcox Corvette: Thanks for the help, what year was that car ? My '80 doesn't look like that. *Edit sorry upon further examination it is the same, I am hoping I don't have to dig down that far and only have to replace the spring, eyelete and reatainer / insulator into the tube poking thru the hub assembly. Everything above that is new.
At this point I think I only have to replace the spring, eyelet and insulator because the housing for this assembly is on that big spring in pic E2 and goes thru the hub assembly. Pic E1 shows the eyelete in the tube in the upper right part of the hub
Only I am not sure how to install it. It also says to cut the eyelet or pin to 3/4" for my year.
I am assuming this is how the horn works, when you push the horn button it results in the eyelet making contact with the big spring which acts as a conductor to active the horn ?
It hard to see from the pic but that tube pokes right thru the hub assembly and has a notch at the top to hold the black insulator in, you can see the little nub on the small black insulator. They say to cut that eyelete to 3/4" and that is exactly how high that tube part is, problem is I am not sure how to assemble these three parts in the tube
I am going to try and use the existing spring in E2 so I don't have to pull anything else apart
And thanks for the extra links Roger I am going thru them right now
Install the spring,slide the little black plastic piece over the pin,install pin head down against spring,lock black piece in,pin will be wobbly but once you install the horn contact it will be fine.
"I am assuming this is how the horn works, when you push the horn button it results in the eyelet making contact with the big spring which acts as a conductor to active the horn ?"
No, these pieces don't move after installation,they just bridge the gap,you could just stretch the spring out and use that in place of all 3 pieces and I've seen that done.
The horn contact does all the work.
The horn is a grounded system, so the horn is waiting for ground. The cap snaps on the upper contact and is insulated until you push it. This makes the upper contact complete the grounding and the horn blows.
Btw thanks for going thru all the trouble of making a diagram
