I know that this octane, timing issue has been discussed a lot. But I need to ask a couple of questions. I timed my 1970 350/300 to 12* and 30* full on 93 octane no ethanol. If I try 91 or 89 octane will I have to retime the engine to run on that fuel? How will lower octane effect the engine temperature?
Curious why you're wanting to drop fuel octane if you've got 93 availible. According to my manual, a 70' 350/300's 10.25 compression, which is quite high. If for some reason you do need to go down in octane, listen for engine pre-ignition pinging under acceleration. If getting it, pull a couple degrees of initial timing out at a time, until it goes away. Of course you're going to loose some power in doing this.
You are already running a low total number of 30, most people run 36. A 10:25 engine as stated above needs 93. The engine will not run hotter unless it starts to knock.
Went on a cruise the other day and had to get gas along the way. The two stations in town both had 91 as their premium. I had to take what I could get. The car seemed to run fine on the way back, might have run a smidge hotter. So I thought that if the car ran OK on 91octane I might be able to save a dollar or two by going to 91. Just wanted to make sure that the timing was correct for the octane.
