A Comment(+) on the VBP Rear Composite Spring
Replacing the old 9-leaf and basically worn-out OEM steel spring was one of the best mods I have done. My old 1974 is like a new car. The old steel was bang-bang-bang on bumps; the new is a gentle up and down controlled motion. The Wife says thank you! The shocks (new Monroe Gas-Matic) are not fancy as advocated by many, including VBP, but control is fine for cruising. A friend did the job for me and it was pretty straight-forward. I really preferred rubber cushions (not an option) but poly seems OK so far. The rear sits a little high (see pic from yesterday) but I have about 1 1/2" of the 8" spring bolts to work with to fine tune the height. I will do so when things settle down.
Criticism, why not? The instructions (photocopies of photocopies, are hardly readable) and the readable disclaimer says, "Heat shields are recommended in ALL applications. DAMAGE FROM EXCESSIVE HEAT WILL VOID WARRANTY". And yes we did install mat heat shields from fire-fighting equipment vests with SS straps. They should be fine and I do have 3" clearance. BUT, given that warning:
-no heat shield is offered by VBP as standard or an option as with TRW
-no suggestions are made as to what a heat shield is?? Or where to get it.
VBP, I really like your product but marketing could use a little up-date. Just trying to be constructive!
Still very pleased with the spring thus far, and it matches well with the front end redo/upgrade I just finished (VBP 460# springs).
ride is wonderful with the Bilsteins, a late addition, cured that undulating bridge construction here that drove me krazy driving over it....the KYB's used to bounce bad....
*BTW* - About 125 miles since the original post. I love this spring. What a difference from the old steel! One of the best mods I have ever made. Driving is so much more enjoyable.
Maybe a topic should be done on what has been used as a shield, esp. something we can get in a small amount.
this is Thermo Tec Exhaust wrap I used on Pauls old 67, kit came with a handful of stainless straps but not enough to do the job so I finished it off with tie wraps, I never had to replace 'em, dont know if Paul ever had to or not. Put those plastic deals on around 1997.
Paul, enjoy that new spring, I put one of those on the 73 a couple yrs ago after my TRW bit the dust. I am sure the failure was due to the hauler using the spring as a tie down point when I had the car moved from Fla. Failure didnt occur until a few weeks after I got the car back to TN, pulled in the driveway and heard "craaaaaack" !! Glad it didnt happen on the road. Couldnt have been heat damage as my car has always had side exhaust.
anyways, Paul, your car looks great !!
My spring is heat shield wrapped with aluminum tape with some kind of 1/16" or so gummy stuff on the inside. I then wrapped it with electrical tape. I figured if it got hot enough the electrical tape would start to deform but never had a problem. Put a heat gun on the spring right under the exhaust pipe after a long drive on a hot day and it read around 100F nothing better than an air gap for insulation.
Paul if you haven't done it yet try the Bilsteins they are more than worth the money. You won't believe the difference
With the 1974, SS straps were used. I picked up a couple of packages of them (four straps in each) from a local auto parts supplier. Cost was about $20.00 for both.
I have no doubt that Bilstein makes a fine product. But I put on four new Monroe gas shocks just last year. And they seem OK for my type of mild driving.
