stuck pilot bushing
Old Aug 17, 2011 | 11:43 PM
another-user's Avatar
another-user
Default stuck pilot bushing
seems like every finishing step i have on this rebuild is going wrong.
anyways, ive got a stuck pilot bushing on my 69 small block. i tried the puller from autozone and snapped that this evening. i also tried finding a socket to fit in the bearing and filling the thing with grease, but i dont have any that fit tight enough. im going to try turning down an extension tomorrow to hopefully fit, but im not holding my breath.
are there any other suggestions on getting this thing out? not only is it destroyed now that i tried pulling on it, its way way out of spec. my calipers showed it at about .697-.699, my new brass one is .585.
Old Aug 17, 2011 | 11:53 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Sometimes they are in there so hard you have to cut them out.
Old Aug 18, 2011 | 12:36 AM
OMF's Avatar
OMF
My tool that I used for removing the bushing using the grease method was loose fitting as well. I just used some black tape wrapped on the outside of the tool until it was a very snug fit....several solid wacks later the bushing was out.....good luck to you
Old Aug 18, 2011 | 02:27 AM
richiev88's Avatar
richiev88
I found the grease method the best, you can use a old input shaft and a BIG hammer, or turn up some bar to suit, hammer away.........
Old Aug 18, 2011 | 02:56 AM
Dino_'72's Avatar
Dino_'72
Had same problem years ago. Used a cold chisel and hammer. Took it out in pieces in a few minutes. Crude but effective. Used an old input shaft to press in the new bearing.
Old Aug 18, 2011 | 06:44 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Use a tap and die set to create some threads to fit a common bolt that will work at a slight oversize from what damage you've done to it. Put some grease in the hole and then thread a bolt into it. Tighten it down until the bushings starts moving.
Old Aug 18, 2011 | 06:49 AM
pws69's Avatar
pws69
A piece of a wooden dowel will also work fine.
Old Aug 18, 2011 | 08:19 AM
...Roger...'s Avatar
...Roger...
I've heard you can also substitute wet bread for the grease.
I use CaseyJones method but I just spin in a large bolt with my impact.
I'll get the size and take a pic.
Old Aug 18, 2011 | 08:49 AM
...Roger...
Here's my high tech tool,its a 5/8x11 bolt with 3 slots cut in it.
Old Aug 18, 2011 | 12:11 PM
69 Chevy's Avatar
69 Chevy
The OEM pilot bushing is bronze. Did you try drilling it?
Old Aug 18, 2011 | 12:38 PM
redvetracr's Avatar
redvetracr
try a tap, I use a 5/8 tap welded to a socket. once it bottoms out on the crank the bushing will walk itself out...never fails
Old Aug 18, 2011 | 12:44 PM
TopGunn's Avatar
TopGunn
Mine too, same as Roger
Old Aug 28, 2011 | 11:46 PM
arcticcatmatt's Avatar
arcticcatmatt
thought I would post this for future searches.. wet paper worked for me after other methods failed http://www.youtube.com/watch?v=1xuR7T8G1Ys
Old Aug 29, 2011 | 07:51 AM
Indiancreek's Avatar
Indiancreek
I like that wet paper deal. Have to remember that one. Much cleaner than the grease method.
Old Aug 29, 2011 | 07:59 AM
TopGunn's Avatar
TopGunn
Great Idea!
To stuck pilot bushing
