AC Issue
Old Aug 18, 2011 | 08:04 PM
gireland's Avatar
gireland
3rd Gear
Default AC Issue
The belt on the comprssor broke. It knocked off the power steering belt. How do i tell if the ac compressor locked up?
Old Aug 18, 2011 | 08:26 PM
'75's Avatar
'75
You can grab the clutch on the front and see if it turns, you should be able to turn it seperate from the belt pulley. If you can turn it, try a new belt and see what happens.
Old Aug 18, 2011 | 09:07 PM
EmNash's Avatar
EmNash
Make sure you grab the center part where the clutch is, not the outer part where the belt groove is. The clutch should move in both directions. If it moves replace the belt. If it doesnt check the orifice filter for metal shavings which would mean you are shopping for a new compressor.
To AC Issue
