C3-C4 Rear End Compatibilty
Old Aug 19, 2011 | 12:00 AM
Vette Craze's Avatar
Vette Craze
2nd Gear
Default C3-C4 Rear End Compatibilty
Hello - I have a question about Corvette rear end units and their year compatibility. I have a friend that told me that the rear end out of any 1975 thru 1992 is interchangeable for those years of cars with no modifications. I have to question this - is there no difference between these years? It seems there would be a difference between the C3 and C4?
I’ve got a 1982 that needs help and I found an older C4 rear end (‘85) for sale but thought it wouldn’t work. I know there is the difference between a cast iron rear axle and an aluminum one - just don’t know the years they were used.
Any help will be greatly appreciated, thank you
Old Aug 19, 2011 | 12:29 AM
Shark Racer's Avatar
Shark Racer
Alum diffs were used 80-82. Pretty sure the 85 will bolt on in place of your 82's diff. May have to play with u-joints.
Old Aug 19, 2011 | 05:04 PM
MelWff's Avatar
MelWff
If you look at some vendor sites at 82 differentials and 85 differentials they do not look the same!
Old Aug 19, 2011 | 05:34 PM
Shark Racer
From brief reading... sounds like the rear cover / batwing are 1 piece on the C4s. I don't know much about 80-82 rear diffs. I'd imagine it'd require some kind of adapter plate.
I know that it has been done.
Old Aug 19, 2011 | 05:44 PM
vette427-sbc's Avatar
vette427-sbc
The short answer is no. The rears are different
Old Aug 19, 2011 | 06:04 PM
Shark Racer
You're right, I retract my statement.
Lots of info here:
http://www.vettemod.com/forum/showth...p?t=168&page=2
C3D44 uses a small pinion, C4D44 uses D60 pinion.
This picture says it all:
C4 D44 on left. See 2 bolts near pinion for C-beam mounting that C4 uses.
C3 D44 has mount for snubber by pinion.
Old Aug 19, 2011 | 06:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Vette Craze
...I have a friend that told me that the rear end out of any 1975 thru 1992 is interchangeable for those years of cars with no modifications...
Your friend is wrong.
Old Aug 20, 2011 | 08:30 AM
parkerracing's Avatar
parkerracing
'63-79 is a bolt in (but you may have to play with u joints). '80-82 is an animal unto itself. And C4's? No (unless you have mad fab skillz).
Old Aug 21, 2011 | 02:08 AM
Vette Craze
2nd Gear
Thank you for the input - I found out from a local Vette mechanic that they are completely different. A '78-'81 will work if it came out of an automatic and you can get a '74-'77 to work if you change the stud shaft and it originally came with a small block engine.
Anyway - I now have learned another thing about Corvettes - thanks
Old Aug 21, 2011 | 02:18 AM
vette427-sbc
I believe 63-79 iron rears are all interchangeable. 80-82 is aluminum and uses a different strut rod bracket along with the batwing mount. All of the iron rear stub axles are the same (some used caps and others used straps).
To C3-C4 Rear End Compatibilty
