problem getting a/c pump out
Old Aug 19, 2011 | 09:33 AM
ltblue79's Avatar
ltblue79
Default problem getting a/c pump out
so i cant get the bottom bolt out of the pump that holds it in the bracket to move the pump. is there a trick i dont know about or what? its a 79 if that makes any diff
Old Aug 19, 2011 | 10:12 AM
tyancey00's Avatar
tyancey00
it is threded on the front side of the bracket, if that makes any difference...
Old Aug 19, 2011 | 10:15 AM
ltblue79's Avatar
ltblue79
ya it is. i can back the bolt out almost 2 inches and then it just sits and spins
Old Aug 19, 2011 | 02:51 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Unbolt that top brace that goes to the intake manifold, it may just be causing the bottom of the compressor to bind a bit on the bolt.
Then keep pulling on the bottom bolt.
Old Aug 19, 2011 | 10:04 PM
mikep3's Avatar
mikep3
http://www.corvetteamerica.com/cf/di...c%20compressor
The lower bolt goes through a sleve and is only threaded on the end. The support bracket is threaded on one end.
Mine had to be punched out with a long drift because the sleve was rusted somewhat.
[IMG][/IMG]
To problem getting a/c pump out
