Steering wheel
Old Aug 21, 2011 | 01:20 AM
q8c6's Avatar
q8c6
Default Steering wheel
Hello ,
I feels Steering wheel a little loose while driving it is normal ? if not how i can fix it ?
Old Aug 21, 2011 | 10:18 AM
thegazman's Avatar
thegazman
Default thegazman
Loose steering is not normal, but it could be a lot of different things; bad rag joint, worn steering box, tie rod ends, wheel bearings. ball joints, etc. Jack the car up and have someone move the steering wheel while you look to see what may be worn.
Old Aug 21, 2011 | 10:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If the steering wheel is actually loose, it will be loose while the car is sitting in the drive way. Is it the wheel or the steering?
To Steering wheel
