Does GL5 Already Have Positrac Additive?
Old Aug 21, 2011 | 12:34 PM
jbakyy's Avatar
jbakyy
Default Does GL5 Already Have Positrac Additive?
Hello,
Does GL5 already have Positrac Additive included?
Old Aug 21, 2011 | 12:55 PM
Vette5.5's Avatar
Vette5.5
Not sure if it includes the friction modifier in it, but no way I'm ever putting that stuff in again. Tried it in a few cars, and basically took most of the posi clutch pack lock up away, making it feel more like an open diff, spinning only one tire. Ended up draining and flushing everything out. I'll put up with the noise around turns.
OK, by request, I edited the post as actually meant the GM friction modifier additive and not the GL5 fluid.
Old Aug 21, 2011 | 02:52 PM
jbakyy's Avatar
jbakyy
very interesting, thank you
Old Aug 21, 2011 | 04:29 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
If you are not certain about what to put in your differential, why not just go to the local GM dealer and buy their lube and additive? Suck the old stuff out, fill it with the new, go find an empty parking lot and spend some time making left hand and right hand circles.
Old Aug 21, 2011 | 04:56 PM
jbakyy's Avatar
jbakyy
thank you, what works best for of sucking the old stuff out?
Old Aug 21, 2011 | 05:22 PM
7t9l82's Avatar
7t9l82
I'm looking for the stuff to install a drain plug. that's the best way
Old Aug 21, 2011 | 08:52 PM
Vette5.5's Avatar
Vette5.5
Actually to clarify my earlier post, never used GL5 myself, but was talking about the GM additive. Sorry for confusion.
Old Aug 22, 2011 | 07:10 AM
Faster Rat's Avatar
Faster Rat
A piston or crank suction pump with rubber inlet and discharge hoses. Sold at most auto stores.
Old Aug 22, 2011 | 07:17 AM
jb78L-82's Avatar
jb78L-82
I have been using Mobil 1 75W-90 GL-5 for over 20 years now in the diff-No chatter, no noise, perfect double patches if you spin the wheels, so a little perplexed by the comment above that GL-5 makes a limited slip diff act like an open differential. Anyone else experienced a GL-5 gear oil not working correctly in their corvette diff?
I have not used any additives in the diff with the GL-5 since 1992-works perfectly!
Old Aug 22, 2011 | 12:22 PM
pws69's Avatar
pws69
Sounds like you have posi clutch issues.....
I have also been using Mobil 1 75W-90 GL-5 - plus 1 bottle of the GM Posi additive - for many years without and issues - posi works perfectly.
Old Aug 22, 2011 | 12:32 PM
bashcraft's Avatar
bashcraft
Hello,
Yes it does and it works just fine with no other additives.
Old Aug 22, 2011 | 12:34 PM
bashcraft's Avatar
bashcraft
You need to go back and edit your first post, since it's obviously wrong.
Old Aug 23, 2011 | 06:47 PM
jbakyy's Avatar
jbakyy
thank you. so all i need is gl-5 and do not need the additive, right? some of these and the previous gl5 forums make it confusing.
To Does GL5 Already Have Positrac Additive?
