I helped fellow forum member Darcy Bast move out of his place this weekend in another city a couple of hours away. This was a perfect oppurtunity to stop by Paso's to talk Vette's. We wanted to put the question about frame weights to rest so...
We pulled a bare frame from stroage to try and get an answer.
Here's Darcy Bast and Paso setting the frame on an official scale.
Paso setting up the scale. What will it weigh?
Don't drop that frame Darcy!
And.....a bare 77 (It is a 77, right Paul?) frame weighs in at 276 pounds.
With conrtol arms and crossmembers it weighed in at 371 pounds. Add a steering box and you'd get 387 pounds.
Re: How much does a frame weigh? Well.... (Alwyn678)
Thanks for the info Stingy! My frame also had the three piece front extension attached , along with the front and rear control arms and all the crossmembers, so I am guessing that my frame was in the 400+ LBS area.
Re: How much does a frame weigh? Well.... (Stingy74)
Cool! So if you used aluminum control arms, maybe make an alloy crossmember you could save close to 60-70 pounds... Hmmm better power/weight ratio = go faster = very good!
Re: How much does a frame weigh? Well.... (Wrencher)
Wow, we are Conans!!!
A buddy and me we moved the frame about 300 yards by carrying this thing.
It was a 77 frame also - man, I feel like a bear - look a hair is growing on my chest!!! :lol: :lol: :lol:
OK, no kiddin´: Very interesting info!
Now I know why we were this k.o. after the moving of my frame!!! :bb
You've almost got 1000 posts!
Yea About time I have been hanging around here since Dec /99 Troy was offering A custom avatar for anyone registered in 99 and over 1000 post's Well I think I might be on the **** list for having a home page @ 12 meg.:) I 'll sit tight till I get bellow the legal limit :D Deleting all those useful posting pictures. Oh well ! :)
Then where the heck does the 3,000lbs come from? The engine can't weigh much more than 1,000lbs including tranny. Drive shaft perhaps 100, differential maybe 80 or so. The fiberglass body can't weigh any more than 100. Are the wheels filled with lead?
Re: How much does a frame weigh? Well.... (Rockn-Roll)
Good question :yesnod: but the fiberglass body does weight a lot more than a mere 100 lbs, the sprung weight is a lot too, and the interior also counts, so...... :rolleyes: But still love my vette :jester
Re: How much does a frame weigh? Well.... (inferno-vette)
Corvette bodies are HEAVY. Some friends and I (none of us are small guys) decided a Corvette body couldn't be that heavy, so 4 of us should be able to lift it off of the frame easy enough. Don't kid yourself, 4 guys can't lift a corvette body without doing permanent body damage........to the guys lifting. :D
