just sorta curious. not sure what my 79 L-82 weighs but i would like to find out, and get an idea what the other year vettes weigh. if i remember right, theyre pretty heavy for a fiberglass car. thanks all :cheers:
MY 1966 convertable wieghs 3,080 Lbs, without me in it.....427, Alum heads,alum intake, mini starter, no spare ,no jack, & no spare carrier ...only P/S , side exhaust , 4 speed,,,,,,wieghed her at drags on electronic scale....when the water pump goes will be replaced by alum one...the diet goes on :crazy: if it was so easy for me :) :seeya :flag
My 78 Silver L-48 4-speed weighs 3480lbs. I weighed it at a local business that has a truck scale. The car is stock and I didn't have anything else in the car. :flag
From: The cure for the blues is eight cylinders roaring
Re: What does your car weigh? (7SILVER8)
my car weighs 3420lbs this with half tank of gas ,aluminum intake,aluminum heads,and headers,flexfan,centerline wheels and no driver,but has pb,pl,pw,ac auto trans and spare tire.
thanks all for input.
sharklover, am i to assume your car doesnt have many weight reducing parts on it? so i can figure that my L-82 (1979) weighs around 3300lbs also? thanks :chevy
I'm on a serious diet now hope I'll cut of some serious weight. It was around 1640 kilos with half tank of gas, before the diet. We'll see how it turns out. :cheers:
That's probably pretty close. About the only thing is no A.I.R. pump, which doesn't save much. I also have true dual exhaust, which you might think would add weight but the cat and Y-pipes were so heavy that the duals might actually save a couple pounds. Can't really think of much else. But as mentioned earlier, it's also hard to tell how accurate the truck scale would be at such a light weight.
My '81 has AL heads, electric fans, lighter wheels/tires and significant suspension modifications (though there was little emphasis on loosing sprung weight) and it tips the scales at 3,180 pounds with 1/4 tank (8 gal) of fuel. Further- its 1,580 lbs front and 1,600 lbs rear -> almost 50/50 f/r
