75 Speedometer
Old Aug 22, 2011 | 08:12 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Default 75 Speedometer
I need a picture of a 75 speedometer with the speedometer drive cable attached to it, try to get my hands up there to see if its connected correctly.
The speedometer works, but not right, take off and the needle slowly gets up the the correct speed. Punch it a it takes a while to get up there. It appears to go down at the correct speed.
Is this a cable issue, or a speedometer issue, and or a cable drive out of the trans issue.
Any info welcome.
Old Aug 22, 2011 | 08:46 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Sounds like a speedo issue to me. The first worm and magnets are famous for wearing out.
Do you hear any tinning noise?
Old Aug 23, 2011 | 11:19 AM
Mod75's Avatar
Mod75
No, i don't hear any noise. It just appears to be slow going up.
Will disconnect the cable at the trans ( turbo 400 ) and attach a drill to it and test it out. I thought it might be slipping at the speedo because i had the dash down a few years ago and that's when i noticed it doing that.
Old Aug 24, 2011 | 10:29 PM
0Willcox Corvette
Former Vendor
When you do the drill trick.. listen for a tinning noise
To 75 Speedometer
