Hello, just changed the water pump, thermostat, water neck, bottom radiator hose and water pump. Used a Hi-flow stewart water pump. Car runs normal and does not appear to have any leaks while the engine is running. However, once parked and after some time, there is a bust of coolant that I see on the ground towards the front right (passenger side of the car). Examined all the radiator hoses, heater hoses, areas around the water pump gaskets, area around the water neck gasket - all dry. Almost seems like there is some sort of pressure build up somewhere and it bursts out. Cannot for the life of me figure out where it is coming from and quite puzzled. Any ideas on how I can trouble shoot or find the problem would be really helpful.
I recently had a similar leak, though on the driver side. I eventually found that the radiator side tank was trying to split at the seam, and it would spew out a small puddle right after shutoff.
Also, another idea - be sure that all of the air is out of your cooling system. If you have air in the system you'll experience normal cooling, possibly a little overheating, and then puking.
Hmm, filled it up to the top. But the overflow tank is empty. If it is overfilled, wouldn't it flow into the surge tank first?
Trae, curious as to how you solved your problem.
You need to take off the heater hose from your intake when you are filling up your rad. Once you see water coming out, put the heater hose back on, and then keep filling up you rad till its full. This way you are "bleeding" the air out of your cooling system. Once the air is out, you shouldnt have the puking action going on
