need some wiring help
Old Aug 25, 2011 | 10:16 PM
azguy's Avatar
azguy
Default need some wiring help
I need to wire up and elctric radiator fan and electric choke from an edelbrock carb on my 78. Does anyone have any tips or tricks the used? I am not really sure where to start on this. Thanks for your help in advance.
Old Aug 26, 2011 | 10:05 PM
azguy's Avatar
azguy
Anybody? Do you guys need more information?
Old Aug 26, 2011 | 10:11 PM
'75's Avatar
'75
For the electric choke, run a wire,16 ga should be heavy enough, from the ign or acc terminal in the fuse box to the choke. If there are 2 terminals on the choke, gound the other one.
For the fan wiring, there are lots of wiring kits available. Check your local parts store. If you are good with wiring, me or someone else can post a diagram to follow.
What year is the car?
Old Aug 27, 2011 | 03:45 PM
azguy's Avatar
azguy
it is a 1978, A diagram would be very helpful.
Old Aug 27, 2011 | 10:52 PM
'75's Avatar
'75
Here,s one I found on the web, if you don't want to include the AC relay, just delete it.
Old Aug 28, 2011 | 02:53 AM
azguy's Avatar
azguy
Awesome, Thank you for your help!
To need some wiring help
