1971 Drain Plug Tricks
Old Aug 27, 2011 | 05:20 PM
jbakyy's Avatar
jbakyy
Default 1971 Drain Plug Tricks
hello,
are their tricks to removing the drain plug on 1971. i could not find enough room to get a wrench on the plus and used stubbies. am i missing something?
thanks
Old Aug 27, 2011 | 05:24 PM
gcusmano74's Avatar
gcusmano74
Drain plug for what? Engine oil? Trans fluid? Diff fluid?
Old Aug 27, 2011 | 05:33 PM
scottyp99's Avatar
scottyp99
If it's the engine oil drain plug, you should be able to just put a wrench on it and turn it. If you can't, you have something weird going on there.........
Scott
Old Aug 27, 2011 | 06:25 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Lefty loosy - righty tighty!
Old Aug 27, 2011 | 08:01 PM
bobbarry's Avatar
bobbarry
As a teen, I once stripped out the head of a drain-plug on a '79 Plymouth Horizon; all because I got my orientiation mixed up when upside down and with the drain-plug facing away from me, I was *tightening* rather than loosening the plug...
I filed the outside flats down to 12mm, and it came off as soon as I turned it the proper way.
But on my '71, mine loosens with a simple box-wrench.
Old Aug 28, 2011 | 01:39 AM
arcticcatmatt's Avatar
arcticcatmatt
Look at post number 9 in my thread here (I have a photo of mine).. I have a 71 and getting the plug out is a pain. I am getting an aftermarket with the drain off to the side http://forums.corvetteforum.com/c3-g...otor-71-a.html
Old Aug 28, 2011 | 10:16 AM
rugerm44's Avatar
rugerm44
Take and open end wrench and take it off.I don't have a problem with it.It's tight but its been that way 40years.
Old Aug 28, 2011 | 10:42 AM
7t9l82's Avatar
7t9l82
i use a box end and only a box end, it grips all around and grips well that way. a socket is hard because it can get crooked and slip off. its just not as secure to me.
Old Aug 28, 2011 | 12:38 PM
jbakyy's Avatar
jbakyy
differential drain plug
Old Aug 28, 2011 | 12:39 PM
jbakyy's Avatar
jbakyy
differntial drain plug
Old Aug 28, 2011 | 01:00 PM
gcusmano74's Avatar
gcusmano74
Get a 5/8" open end wrench and, after a few yoga lessons, you can wiggle your hand in there and unscrew the filler plug. Easier, probably, if you loosen it while the car is up on jacks or ramps. You just have to refill it while the car is level. If you can't get under it while it's on the ground, back it onto the ramps, set the parking brake firmly, and then lift the front and jack stand it. Not easy, but doable.
Old Aug 28, 2011 | 02:22 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Our wonderful Vette Differentials are easy to service, because there is only 1 plug to remove! No need to remove 2, because there is only 1!
Old Aug 28, 2011 | 03:19 PM
billla's Avatar
billla
St. Jude Donor '14
Wow...that's an odd duck for sure. That explains why we were all scratching our heads
Old Aug 28, 2011 | 03:48 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
5/8" EIGHT point socket, 12" extension and a ratchet.
Old Aug 28, 2011 | 05:51 PM
jbakyy's Avatar
jbakyy
can you can use a socket on a square drain plug?
Old Aug 28, 2011 | 07:39 PM
PRNDL's Avatar
PRNDL
I don't know about a socket. I think I used a big wrench. The trick is getting to it, which is made a lot easier by removing one of the rear wheels... the passenger side I think.
Old Aug 28, 2011 | 08:40 PM
Phil Zell's Avatar
Phil Zell
yes, with an 8 point socket as mentioned above.
Old Aug 28, 2011 | 09:51 PM
jbakyy's Avatar
jbakyy
i couldn't even get a stubby wrench on the differntial bolt rear end bolt, took me an hour. what is the trick to checking differential oil and filling? does gl-5 already have postirac additive, any oils you would recommend? thanks
To 1971 Drain Plug Tricks
