speed-o-meter
Old Aug 28, 2011 | 02:50 AM
mcmsmsc's Avatar
mcmsmsc
Default speed-o-meter
how hard is to replace the gears for the speedometer in the transmission? thanks
Old Aug 28, 2011 | 09:09 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Nope. Simple job. Take the cable off, loosen one bolt, and slip the gear out of the tail shaft housing. There is either a pin or a clip that keeps the gear in place. I'm relating this from memory, so I may have missed a step but it really is a simple job. Jacking the car up high enough to do it is the hard part.
Old Aug 28, 2011 | 12:35 PM
78 silver 78's Avatar
78 silver 78
Very easy. Pull driveshaft, disconect speedo cable, pull bullit w/ driven gear, 4 bolts on tail shaft, clip holds drive gear in place.
Old Aug 28, 2011 | 02:31 PM
GUSTO14's Avatar
GUSTO14
Sounds pretty easy! Do you know a special trick for getting the tail housing off without removing the transmission from a Corvette first?
Good luck... GUSTO
Old Aug 28, 2011 | 04:34 PM
scottyp99's Avatar
scottyp99
Good luck... GUSTO
Remove the driveshaft in order to remove the tailhousing.
Take a good look at the transmission mount before you get ready to perform this task. It gives you a little more room to work with the speedometer cable if you disconnect the tranny mount and jack the tranny up a little, so, if your tranny mount looks a little worn out, ya might as well install a new one while you are down there.
Scott
Old Aug 28, 2011 | 05:18 PM
mcmsmsc's Avatar
mcmsmsc
dosn't sound to bad. thanks everyone.
Old Aug 28, 2011 | 07:33 PM
78 silver 78
Good luck... GUSTO
To speed-o-meter
