Painted calipers
Old Apr 30, 2002 | 12:10 PM
84ZZ4's Avatar
84ZZ4
Default Painted calipers
I painted my calipers black while doing my brake rebuild. Take a look, I didn't think it was possible to have cast iron look so shiny... :cool:
Oh, and you might want to stay away from the clear coat paint. I tried it to see how it would look and I was not happy:
As you can see, it attacked the paint that I sprayed it on top of. It's the same type of paint and same brand, so I don't know what I did wrong...
Old Apr 30, 2002 | 12:24 PM
verskel's Avatar
verskel
Default Re: Painted calipers (84ZZ4)
:cool: Looks good ! :cool:
As far as paint "attacks" - did you allow plenty of drying time between coats ?
....the 'base' paint must cure completely before applying the clear.
Putting them in an oven or under a heat lamp will accelerate the 'curing' time. :D
Old Apr 30, 2002 | 04:40 PM
zymurgist's Avatar
zymurgist
What kind of paint did you use? High temperature epoxy? I was thinking of getting some red hi-T epoxy for my calipers.
Old Apr 30, 2002 | 08:17 PM
TJKirby82CE's Avatar
TJKirby82CE
Default Re: Painted calipers (zymurgist)
I would like to know as well.-Travis
Old Apr 30, 2002 | 10:22 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Painted calipers (TJKirby82CE)
Very very nice ! They look great :yesnod: . I just painted mine with the caliper paint from MidAmerica (Red :D ).
Old Apr 30, 2002 | 10:40 PM
joshc's Avatar
joshc
I painted mine with high heat Chevy orange, and through my slotted mags they look fantastic.
Old Apr 30, 2002 | 11:14 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Painted calipers (joshc)
I painted mine with Red Devil Polyurethane---non hi temp, over a year ago and they still look great.
Old May 1, 2002 | 02:20 PM
84ZZ4's Avatar
84ZZ4
Default Re: Painted calipers (verskel)
Yes, there was 4-5 days of drying PLUS some oven time (bout 30 minutes) at 200-250 * F and it attacked the paint anyway. It hit some worse than others, as near as I can tell the more coats of black I put on, the worse the clear coat attacked it. What's funny is I steel wooled the calipers down with 0000 steel wool and resprayed the black on top, and it didn't attack any remaining clear coat. Also, I only allowed 3 days drying time + oven heat on the calipers once between coats of black and it didn't attack it either. It has to be something in the damn clear coat...
As far as what kind of paint, it's Duplicolor 500* engine paint. It should hold up fine for the type of driving we do with the car. I wouldn't recommend it if you autocross, road race, or do anything else that expose the calipers to extremely high temperatures for long periods of time. From my oven experiment, 1 hour at 300*F is enough to soften the paint a little. It seems to handle temperature "spikes" much better, so for a street driven car it should be fine.
I'd have used higher temp paint, but couldn't find the gloss black in the higher temperatures.
[Modified by 84ZZ4, 12:22 PM 5/1/2002]
Old May 1, 2002 | 04:45 PM
TJKirby82CE
Cool- Now I have a project for this weekend. Now the only question is red, black or silver....hmmmm-TK
Old May 1, 2002 | 04:58 PM
Justin79-L-82's Avatar
Justin79-L-82
cool.. i'm thinking about painting mine red since i have to rebuild all four anyways (all of them are leaking) ...well so says the 40 point inspection ;)
[Modified by Justin79-L-82, 8:59 PM 5/1/2002]
Old May 1, 2002 | 05:56 PM
Justin79-L-82
Default Re: Painted calipers (Justin79-L-82)
Does anyone have any pictures of what their painted calipers look like?
Old May 2, 2002 | 08:12 AM
Twin_Turbo's Avatar
Twin_Turbo
Here are some (and a diff cover) I did for a buddy.
The paint is Rust-o-leum Hard Hat industrial quality Aluminium paint.
Marck
Old May 2, 2002 | 08:36 AM
groovyjay's Avatar
groovyjay
Looks really :cool:
Old May 2, 2002 | 03:07 PM
84ZZ4's Avatar
84ZZ4
Default Re: Painted calipers (groovyjay)
Well, I'd like to take pictures of them installed, but someone wandered off with my digital camera and I won't get it back until Sunday...
Old May 2, 2002 | 08:19 PM
Justin79-L-82
as anyone painted their calipers with them still on the car?
To Painted calipers
