Compressor Bad?
Old Aug 31, 2011 | 10:47 AM
Frisco71's Avatar
Frisco71
4th Gear
Default Compressor Bad?
The clutch on my 71 compressor spins freely and I can spin the inside front of the compressor freely, but it locks up when turned on. Does this mean it is frozen?
Old Aug 31, 2011 | 12:37 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Not necessarily. Are you spinning the pulley by hand, or the actual clutch hub?
The pulley will still spin even if the internals are locked. If the clutch hub spins its probably not locked.
Is it a hard mechanical lock up, or just a belt that starts slipping? If it runs for a little while before it starts slipping, its probably the latter.
In that case it could be "locking up" due to a loose belt, or excessive high size pressure which makes it hard for the compressor to turn.
High pressure could be caused by being overcharged, by a restriction in the system, or even by poor airflow through the condenser.
Old Aug 31, 2011 | 01:05 PM
Vette5.5's Avatar
Vette5.5
"Driveshafts" got it covered pretty good. The compressor has an electric clutch, that only actually engages the compressor, when switching the A/C system on. If the units totally locked up, smoking the belt, then possibly internally frozen. As already mentioned, could be way overcharged. If the A6 is shot, and not caring about originality, brobably go with a more modern replacement. A6's are real leakers, and really sap the hp.
To Compressor Bad?
