wiper motor test?
Old Sep 2, 2011 | 08:41 PM
dmayhew's Avatar
dmayhew
Default wiper motor test?
My wipers just stopped working last Saturday on my 71 car. The door opens , so vacuume is working. But the motor does not come on. The micro swtich on fire wall is fully activated. I used a test light and the yellow center wire was hot at the connection to the motor.
I have removed the motor. Can you test the motor with a dirrect connection to a battery?
David
Old Sep 2, 2011 | 09:14 PM
...Roger...'s Avatar
...Roger...
David
Did you touch either of the other 2 wires in the 3 wire connector with your test light?
Here is a test,click on supporting documentation.
http://willcoxcorvette.com/repairand...elp.php?hID=95
Old Sep 2, 2011 | 09:35 PM
...Roger...
One of the first things I do is probe the lt blue,if the motor runs its not a motor problem.
Old Sep 3, 2011 | 01:14 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
David-
Here are the testing videos...
1968
1969-1972
They kind of go hand and foot with the paper I did.
Ernie
Old Sep 3, 2011 | 07:07 AM
dmayhew's Avatar
dmayhew
Thanks you to each of you that replied.
Great help from all
David
Old Sep 5, 2011 | 01:14 PM
0Willcox Corvette
Former Vendor
David-
Post again if you can't figure it out or if you fix it.
Ernie
Old Sep 5, 2011 | 01:52 PM
dmayhew's Avatar
dmayhew
Originally Posted by Willcox Corvette
David-
Ernie
Thanks Ernie,
I am also replacing the steel vacuume tube that crosses the firewall.
Can not reinstall the motor until I get part installed.
The bench test proved the motor was OK, After I started using good judgement and testing procedures from your tech bulliten I beleive I had somehow turned the overide switch off at some point.
Hard lessons stay with you for ever.
David
Old Sep 5, 2011 | 09:35 PM
0Willcox Corvette
Former Vendor
Good Deal David! Glad to help!
Old Sep 8, 2011 | 03:50 PM
dmayhew's Avatar
dmayhew
Default Ttt
Ttt
To wiper motor test?
