Panel Bonding
Old Sep 3, 2011 | 10:14 AM
markyta's Avatar
markyta
Default Panel Bonding
I am putting a complete 1 piece nose on a '71. Any idea how many 3M bonding adhesives I would need? Thank you.
Old Sep 3, 2011 | 10:51 AM
jnb5101's Avatar
jnb5101
i used 3 tubes. i bonded the front attachment points(by the nose) and then after that set i bonded the rear areas by the firewall. there's enough flex so that you can pull the areas by the doors out enough to insert the material. the think the pucker factor was about a 12 on a scale of 10 when i did this! that's why i did it in two stages. there were some large gaps that needed a lot of adhesive. i might behove you to get 4 tubes. it seems like there's always some other little thing that you want to bond later.
