73 350 won't start
Old Sep 4, 2011 | 05:50 AM
Rodman Wilder's Avatar
Rodman Wilder
1st Gear
Default 73 350 won't start
73 vette, I replaced the 454 big block with a new crate 350. This engine came with a HEI no coil and a new TCI starter with only two wires, my alternator had a bad connections and it fried my wirers and I’m in the process of putting a new wire harness in, I wirered up the alternator the starter and there where three wires red, purple, yellow,,I put the red wire in and I put the yellow wire in and have the purple left,,but it did crank over, but it would run,,did I use the right wires to the starter and I have allot of wires left, any ideas, thanks.
Old Sep 4, 2011 | 07:26 AM
JimT's Avatar
JimT
Did the original engine have the HEI distributor? If not, you need to provide a solid 12V supply to the HEI, not the distributor wiring from the old distributor.
