Dynomax headers glowing in the dark ?
Old May 2, 2002 | 08:21 PM
candyapplevette's Avatar
candyapplevette
Default Re: Dynomax headers glowing in the dark ? (MARKUS_P)
Thanks for the welcome guys.
The short block is not rebuilt but everything is sound in it with good oil pressure and compression, no blowby.
I know that a rich mixture as well as a lean mixture will cause headers to glow and also timing will cause the problem but, I think I have eliminated those by trying 2 different (both brand new) distributors and 2 different (again both new. 1 Holley 1 Edelbrock) carbs.
I have tried jetting both lean as well as rich and have adjusted initial timing from 4 up to somewhere around 36 and even tried setting timing at full advance between 32 & 38 degrees without regard to initial and nothing helps.
I have the heads back off as of last night and placed a dial indiacator on the piston to find top dead center to verify that my new balancer was phased in correctly and it all checks out.
The headers have been hot enough that when I pulled the headers out of the car the pressure against the heater box caved it in so I have just rebuilt the side of it.nonod:
I think I am about to give up on this and build a fresh 406 using the ported aluminum Corvette heads I already have, any input if I do decide to build the 406?
Thanks for the help. :
Old May 2, 2002 | 08:23 PM
candyapplevette
Default Re: Dynomax headers glowing in the dark ? (candyapplevette)
I almost forgot, I am running duel 2 1/2 inch exhaust with Flow Master Mufflers and no cat.
Old May 2, 2002 | 09:10 PM
PatsLs1vette's Avatar
PatsLs1vette
my old 76 did it when we put the 12:1comp 327 in it with hooker super comp. headers on it they glowed, almost see through,we put a msd 6a box on it and imediatly the glowing stopped..like gkull said problem was it was too rich and the fuel was burning in the pipes, it needed the hotter spark to burn it properly.
