Ok.. I just got this car two weeks ago.. so far.. i have repaired the non opening headlight doors.. great info up here... a non working horn... again great info from the site.. turned out to be the button was not making contact..
Now my biggest delima.. the seller said something about a fuse but I cannot remember... There is no response at all when I move the speed lever or any switches on the ac unit controls. The compressor does not run nor does the fan blow...
When do I start.. I saw a post about the vacuum control unit but where is that located.. I have never done AC before so I need very specific guidance to get the system working again..
Any help is much appreciated..
Also as I saw in another post.. there is no hissing in the cabin when I move the switches..
Just fixed the same issue with my 80'. There's a relay under the hood that went bad, It's on the right side near the hood spring. It was a quick fix and the system works great now. Of course there are other things that could have gone wrong like a bad motor switch, but the relay is more likely the issue.
I just found the 25amp fuse and repalced it... the fan runs fine on the defrost.. heat and vent.. as soon as I move the control to the ac side it blows the fuse.. I disconnected the ac compressor to see if the short was there when engaging.. it blows regardless if its connected or not... does this still sound like the relay on the firewall?
ok.. I checked the ac leads.. they had been spliced but not touching.. I removed the tape and they had electrical connectors on them.. then I noticed the solinoid lead was not connected... I hooked it up and the fuse did not blow.. the compressor did not run but I am assuming its not charged.... am I getting closer to a fix?
... then I noticed the solinoid lead was not connected... I hooked it up and the fuse did not blow.. the compressor did not run but I am assuming its not charged.... am I getting closer to a fix?
The lead may have been grounding since fuse did not blow so sounds like you got it.
when I turned the key.. the solenoid on the carb bumped but the clutch on the Ac compressor did not engage... is it the switch or low... can I bypass the switch without damage to my electrical (over ride it) to see if the clutch is forced to engage?
when I turned the key.. the solenoid bumped but the clutch did not engage... is it the switch or low... can I bypass the switch without damage to my electrical (over ride it) to see if the clutch is forced to engage?
Yes you can jump the switch & hear it click on w/o running....
bypassed switch... clutch engaged! started engine for a few seconds.. clutch engaged and ran.. not seized... does it only need a charge.... also its R12.. I assume I need to get it converted..
Thank you so much for all your help... This forum is great and the members are very knowledgeable... I was able to diagnose every issue this car had that previous owner did not address..
Now if I can figure out how to remove the console cover / gauge cluster I can install new bulbs.
Hey.. YOU really helped.... you have Corvette repair to a science..
Thank you very much for your help and quick responses.. I was running outside and back to the computer diagnosing... It was very cool havign the fast responses waiting... THANK YOU AGAIN SOOOO MUCH
