82 fuel sock replacement
Old Sep 5, 2011 | 04:24 PM
leebay's Avatar
leebay
Default 82 fuel sock replacement
I am replacing my 82 fuel pump with a 85 pump and I am ready to re-install except I am not sure in what direction the fuel sock installs. If i install it like it was removed the long side of the sock is in-line with the fuel return tube and blocking flow. Please Advise
Thanks for your help
Old Oct 3, 2011 | 11:29 PM
pakrat12's Avatar
pakrat12
I had to pull my 82 pump/sender from tank last week because a bumpy road caused the pump hose to disconnect. I replaced the hose and sock and had the same question about the sock. I googled "82 corvette fuel pump images" and found a picture of the unit and used it as a guide.
