Charging question.
Old Sep 6, 2011 | 04:42 PM
scottyp99's Avatar
scottyp99
Default Charging question.
Hi, everybody,
I finally got my carb repaired, after I snapped an ear off of the baseplate because I don't know my own strength, and sure enough........the battery was dead. So, I jump started it with my pick-up. Started up, but now, as soon as I remove the jumper cables, the engine stays running, but gradually drains the battery and then stalls after a couple minutes. If I charge up the battery again with the jumper cables, same thing: It'll start, run for a few minutes until the voltmeter gets down to about 8, and then die. Also, if I disconnect the battery while it's running, it dies. I should be able to disconnect the battery while the car is running, shouldn't I? I brought the alternator down to Advance Auto and had it tested on their machine, it passed just fine. I have gone over the cables superficially, and there is nothing that looks like it would be a poor ground, although I suppose that doesn't really mean anything. I have had a key-off draw problem for sometime, and the battery has been drained dead several times, could it just be that the battery is now junk?
Scott
Old Sep 6, 2011 | 05:16 PM
69 Chevy's Avatar
69 Chevy
Advance Auto, aren't they in the auto parts selling business? You'd think their battery tester guy would jump at the chance to sell you a new wet cell. Perhaps it would be a wise move to drive there and have your charging system checked. Ya think?
Old Sep 6, 2011 | 05:23 PM
...Roger...'s Avatar
...Roger...
Off the top it sounds like the alternator is not putting out. Try this and see if this tells the alt to start putting out.
Old Sep 6, 2011 | 05:34 PM
scottyp99's Avatar
scottyp99
Well, that would seem to be the obvious move, if it weren't for one thing: the car runs for a couple of minutes and then dies. Doesn't run long enough to get it to Advance Auto, or anywhere else, really. I guess I could have it towed on a flatbed down to Advance, maybe I should do that. Ya think?
Scott
Old Sep 6, 2011 | 05:43 PM
...Roger...
Does your battery light in the dash come on when the key is in the ON position-it must for the alternator to work. Check your gauges fuse , it powers the battery light.
The test light in the above pic takes the place temporarily of the Battery light.
Old Sep 6, 2011 | 05:49 PM
69 Chevy's Avatar
69 Chevy
Push it with a bulldozer if you think it's best, or that's all you have to get it to someone smarter than you are.
Old Sep 6, 2011 | 05:55 PM
scottyp99's Avatar
scottyp99
I can see in the quote that there is some sort of image there, but I cannot view it on my computer, so I can't tell what you are refering to.
I am kind of a knucklehead when it comes to anything electrical, but I have just been looking around on the internet, and have found a place that says if you measure the battery's charge at rest, and then measure it while it's running, and the charge is lower when it's running, you need a new alternator. Well, the tester passed my alternator, so all I can figure is that the electricity generated by the alternator is not getting to where it needs to get to. If I jumpstart it, it just runs off the battery until it sucks all the juice out of it and dies. I don't get it, and I don't really know what the next step in the process should be.
Scott
Old Sep 6, 2011 | 06:00 PM
scottyp99's Avatar
scottyp99
My bulldozer won't start either, it's turning into a pretty bad week, vehicle-wise! Wait, I know what to do.........
Plasky!!!! Gas up the jet!!!!!!
Scott
Old Sep 6, 2011 | 06:04 PM
...Roger...
The alternator needs to be excited by the Battery light in the dash , if the bulb is burned out you r alternator will act like your describing-no output.
Do you have a 12 v test light ? If so I can tell you how to create a temporary Battery light circuit to see if your alternator will function.
Old Sep 6, 2011 | 06:11 PM
scottyp99's Avatar
scottyp99
I can't see the pic, is the test light used as some sort of jumper wire to connect two things to trick the alternator into thinking that the battery light is on? Anyway, now that you mention it, no, the battery light doesn't come on. I will check fuses tomorrow morning, and post again on thursday. Thanks, Roger,
Scott
Old Sep 6, 2011 | 06:15 PM
scottyp99's Avatar
scottyp99
Yep, I have a test light, please describe what to do.
Scott
...Roger...
Yes the pic is showing how to connect the test light to the alternator. If you want to PM me an email address I can send you the pic. Its a 1 min simple test.
Old Sep 6, 2011 | 06:19 PM
scottyp99's Avatar
scottyp99
Awesome!! PM on the way soon, and thanks, I hope this works out.
Scott
Old Sep 6, 2011 | 06:20 PM
...Roger...
On the back of your alternator you have a large pos post and on the top you have a 2 wire connector with a large red wire and a smaller brown.
Connect the alligator clip on your test light to the large pos post on the back of alt.
Then put the probe down in with the brown wire in the top connector.
Careful getting the cap off the large pos post,don't use a screwdriver.
Old Sep 6, 2011 | 07:26 PM
scottyp99's Avatar
scottyp99
Well, OK, I'll try it out tomorrow. if this turns out to be the problem, then what? Check guages fuse? My guages work. Replace the bulb behind the battery light?
Scott
Old Sep 6, 2011 | 07:32 PM
...Roger...
If it works then you need to find out why the Battery light circuit is open or dead.
The circuit needs 12v so a blown fuse could be the prob but if the gauges work that's probably not it.
The bulb could be burned out.
Probably the most common problem with this circuit is the printed circuit in the center cluster. Where the large plug goes in the back the thin brass contacts can fold over.
After the test,pull the 2 wire connector and check the brown wire for voltage with the key on.
Old Sep 6, 2011 | 08:29 PM
scottyp99's Avatar
scottyp99
Okey-dokey, Roger, I won't be able to post again until thursday afternoon, unless I really need input, then I can go down to the library, I guess. Thanks again,
Scott
To Charging question.
