76 header install pics
Old Sep 6, 2011 | 09:50 PM
Tim H's Avatar
Tim H
Default 76 header install pics
As if anyone cares but maybe helping just one person who thinks header install on a vette is like building a space ship! (Summit Headers)
Anyway I didn't really expect to have to remove the zbar but lucky I did because the ball into the engine block was falling out!
Anyway so far on the drivers side needs no dents at all.
The closest spot is the Zbar and I can almost slide a finger inbetween it and the header tube.
Just for the fun of it I might dent the bottom of the tube a little so I can get a finger between the two.
Nothing and I mean nothing is in the way!!!!
If you want headers do it, this way you can drive it to the exhaust shop with open headers like im going to !
[IMG][/IMG]
[IMG][/IMG]
Old Sep 6, 2011 | 09:53 PM
68FireBird's Avatar
68FireBird
Nice, what about AC side?
Old Sep 6, 2011 | 09:59 PM
Tim H's Avatar
Tim H
That will be in a day or two but I threw the air in the trash, this car is a hotrod!
Old Sep 6, 2011 | 10:42 PM
another-user's Avatar
another-user
i just installed a set of these on my 69. tube #4 had to be dented slightly for plug wire clearance.
the collector on the passenger side is too far outbound, and comes RIGHT underneath my floor boards, and about a mile away from the tranny crossmember.
my biggest complaint though is the bolt hole/tube spacing. i installed studs and nuts, and those nuts were scrapping against about half the header tubes. makes installing/removing the headers take forever. plus it all has to be done with a wrench.
Old Sep 6, 2011 | 10:45 PM
7t9l82's Avatar
7t9l82
did you break any bolts? and did you do anything before you started like soaking with liquid wrench etc
Old Sep 7, 2011 | 01:06 AM
Tim H's Avatar
Tim H
One day a couple of weeks ago I was just looking at stuff for problems and all my exhaust manifold bolts were finger tight so they are all coming out with no problem!
Old Sep 7, 2011 | 07:55 AM
Roco71's Avatar
Roco71
I installed Summits on my 71 with AT. went on without any problems.
Old Sep 7, 2011 | 09:56 AM
sakins.02vert's Avatar
sakins.02vert
HI Tim, funny you say that. I have a 76 and I was under the car last weekend looking around and noticed the bolts to the exhaust manifold were falling out and some missing. Seems like the threads are pretty short, wondering if the guy who rebuilt the engine years ago used the wrong bolts? Anyway, since the exhaust manifolds are stock, wondering if I too should go with some headers. But from reading on the forum I think I should get ceramic coated for heat reduction. Thanks again for the pics and info that I shouldn't have any clearance problems with the ones from Summit.
Old Sep 7, 2011 | 01:18 PM
Tim H's Avatar
Tim H
Summits are a good set of regular install headers.
Now if coated headers are built the same and I didn't have to dent them that would be a good choice also.
Exhaust manifold bolts have to be tightened alot at first because they get hot and cold all the time and that is what loosens them.
Old Sep 10, 2011 | 12:15 AM
Tim H's Avatar
Tim H
Here is the passenger side.
[IMG][/IMG]
Now a few things to take note of.
Starter wires are now real easy to get to as is the plugs and wires.
Make sure your rubber fuel lines are in excellant shape and not leaking because there is only about maybe 4 inches between then and a very, very hot header tube.
Im going to see how the starter reacts to the heat also and if it dies im going with the external solenoid set up and that will be the end of that problem.
Oh yes not one dent has to be put in these headers.
Im used to Oldsmobiles where you have to grind your a-arm and beat and bang the headers to death and raise the engine up 5 inches just to squeeze them in!
So next will be the exhaust set up from a shop.
Old Sep 10, 2011 | 06:37 PM
Tim H's Avatar
Tim H
Started it up today with open headers!
I DON'T WANT ANY EXHAUST BUT PO PO SAY YOU HAVE TO HAVE IT TO DRIVE ON THE STREET!!!!
Old May 6, 2020 | 01:51 PM
ramez75's Avatar
ramez75
I am done with the install and drove it for like 6 to 7 miles. Definitely louder and sounds like a race car but when idling it very quite. Also, I did not get any errors or engine check light because I eliminated the rear O2 sensor, i mean using the rear as the front.
Next i will take the PCM out and mail it to East Coast for tuning
To 76 header install pics
